1993 Acura Vigor Will not turn over.
1993 ACURA VIGOR
101,000 MILES • 4 CYL • FWD • AUTOMATIC
SCOTTI8570
1993 Acura Vigor will not even try to start. Tried jumping, disconnecting battery, removing the #39 back-up fuse etc, still nothing. Everything lights up as normal with the ignition and works except the motor!!! Any help would be greatly apreciated.
Apr 10, 2009 at 11:55 AM
KHLOW2008
  • 41,814 POSTS
Hi scotti8570,
Something is missing causing the non starting. The following link should have some answers for you. Check it out and let me know what you find.
https://www.2carpros.com/kpages/first_things.htm
Apr 11, 2009 at 3:21 AM
