1993 Acura Vigor ignition
256,652 MILES • 6 CYL • FWD • MANUAL
NJACKSON9900
I need to replace my ignition (keys were lost) I was told only the lock tumbler (?) was what needed to be replaced...what needs to be taken off? Seems there is a little screw in the old one, however it seems impossible to take off, there are too many parts of the steering column above it...is this all we need to get to? If so how do we get to it?
THANKS
Jun 9, 2008 at 3:44 PM
KHLOW2008
  • 41,812 POSTS
To remove the key cylinders, you need the key to be turned to ACC and press the release pin to pull cylinder out.
Aug 11, 2008 at 1:27 AM
