1993 Acura Vigor
1993 ACURA VIGOR
218,372 MILES • 6 CYL • FWD • AUTOMATIC
DAVID LOPEZ
hello:
My car is locking both front brakes after a few miles. I have to wait for about 30 minutes then it will release on its own. risently my brakes were gone they replaced the master cylinder and it worked well for a few months then started to give this problem. I had the brake pads replaced but it is doing the same thing.
Jan 8, 2008 at 1:55 PM
  • 31,937 POSTS
Hi there,
Have the master cylinder pedal free play checked, as if it is tight the pressure will be applied to the brakes, as it heats up the pressure will increase, and releasing as it cools down, So check pedal free play first and if there still is a problem re post for more checks.
Mark (mhpautos)
Jan 8, 2008 at 2:02 PM
