1992 Acura Vigor Starting and Muffler issues
1992 ACURA VIGOR
FLACREATURE2001
I have a 1992 Automatic Acura Vigor with around 138,000 miles on it that has issues starting. Typically it will start and run fine in the mornings and the evenings but not so much during the day. However it will go through spurts of starting for a few days then one day it will switch and not start. When it doesnt start it will typically have to sit there for a few hours before starting again.
I have taken the car to three mechanics and they can not slove the problem. They have checked the car on the computer and nothing. What could possibly be the problem as I tyically leave the car on instead of turning it off to go into a store?
The area where the muffler is connected has rusted through so what is the expected cost of having this repaired?
Please keep in mind my knowledge of cars is very limited.
Thanks
Aug 6, 2007 at 2:30 AM
BRUCE HUNT
  • 3,754 POSTS
Did your mechanics check the EFI relay for bad connections or replacement. I might start with that. On the exhaust, I would call the local muffler shops and see what they are going to charge. Check with a couple of different places.
Aug 6, 2007 at 3:48 AM
JMPATEL10
I have Acura Vigor 1993 Automatic and have same problem of starting.Morning and evening it starts.But when hot in the afternoon it cranks but do not start.What is EFI relay and where it is located?
Sep 14, 2009 at 5:03 PM
