What is the best plan of action for removing the bolt for the harmonic balancer? We are trying to replace the water pump on the 5 cylinder engine for the Acura Vigor. The cooling fan and the radiator have already been removed. All the belts have been removed. The upper timing belt cover has been removed. The lower timing belt cover is behind the harmonic balancer and the balancer will not come off without removing the crank shaft bolt. Is this a reverse threaded bolt? Is there a factory tool or process to remove this bolt? Do you have a full engine diagram available?
May 25, 2010 at 1:51 PM
