1992 Acura Vigor Distributor
GEE125
Electrical problem
1992 Acura Vigor Automatic
Is there a fuse that powers the distributor. I am not getting any spark from the distributor.
Jul 7, 2008 at 7:13 AM
KHLOW2008
  • 41,812 POSTS
Hi gee125,
The spark is powered by the ignition coil, the distributor only distributes the sparks.
The cam sensor is located behind the cam sprocket at timing belt side.
Check for power to ignition coil. Is the cam shaft turning (timing belt problem) ?
Aug 11, 2008 at 1:30 AM
