ok i hope you can help me. i have been in and out of the repair shop for 2 months. ok my car vibrates between 2000 and 3500rpm under acceleration and when engine braking to a stop any gear. although 5th and 6th gear you don't feel it as much. after the problem started i replaced the axles made it a little better. i replaced the mid-shaft and all the bearings attached to it, i also replaced the differential for an lsd i changed the clutch and flywheel. had the clutch and flywheel removed. I balanced the flywheel and installed a new clutch for the second time i am out of ideas.
Aug 20, 2009 at 7:45 AM
