2005 Acura TSX Pulls on Left Side
53,000 MILES • 4 CYL • FWD • AUTOMATIC
DAMIN15
I took it to the Acura dealer to get it repaired. Instead they did not solve the problem it still pulls on left side and when i took it back the same day their reason was poor quality tires on the car. They performend 4 wheel alignment. Align alignment 21.
I bought new BF Goodrich tires over the summer.
BF Goodrich g-Forceâ„¢ Super Sport A/S H
Recommended tires are by Michelin
Mar 12, 2010 at 1:47 PM
JEREMIAH
  • 217 POSTS
radial pull is is not common but neither is it unheard of.
rotating the tires against the pull is the easy way to find out and fix radial pulls.
if the front and rear tires have the same tread/wear pattern, rotate the front tires left to right, if the car pulls the opposite direction, then the tires are to blame
Jun 20, 2010 at 2:15 AM
