2004 Acura TSX Why is Alignment required
2004 ACURA TSX
130,000 MILES • 4 CYL • FWD • AUTOMATIC
WILLIAM1956
When replacing four wheels because the tread is low, why is it alignment necessary? What problems occur if the alignment is skipped?
Sep 9, 2010 at 9:07 AM
SATURNTECH9
  • 30,869 POSTS
You only need a alignment if the car is out of alignment.If it's out of alignment and you get new tire's and don't have it aligned the tire's will wear out unevenly and prematurely.
Sep 9, 2010 at 9:25 AM
