2004 Acura TSX brake and shift
52,000 MILES • 4 CYL • 2WD • AUTOMATIC
PABLO_DA
when I turn on my car, to put it in drive or reverse, I have to step into the brake pedal and at the same time move the stick into drive or reverse, the thing is that lately I've been having trouble to move the stick into drive or reverse it wont move, it is moving when I try it like 5 times or even more, and I always step into the break pedal and then I try to move it at the same time as usual, What is the problem? Does it have to be with the brake pedal or the stick.
Aug 28, 2009 at 4:42 AM
KHLOW2008
  • 41,812 POSTS
Hi pablo_da,
When you are not able to shift out of park, check if the brake lights are working. If lights do not work, it would not operate the shift interlock solenoid to allow the gear lever to be moved out of park. The most likely problem would be a failing brake switch.
Sep 7, 2009 at 4:26 AM
