Air Conditioning problem
2004 Acura TSX Automatic 51000 miles
Over the past few months I have been having problems with my air conditioner in my 2004 Acura TSX. First, it was only blowing hot air--no cold at all. The shop at first thought that I needed a new compressor but then changed their minds. They replaced a compressor switch(?) and replaced the left fan. Now I have found that when the atmospheric pressures are high as with high humidity days, the air conditioner does not blow cold air. The air that comes out is like if only a fan were on not air conditoned cold air. When it is not humid, the AC seems to work fine. It's as if the air conditioner will not "kick on" if the outside atmospheric pressure are elevated. What could be wrong?
Oct 1, 2008 at 10:05 AM
