1996 Acura TL Exhaust Leak Noise
NAIEFELYEMENI
i have a96 acura tl 2.5 with 135,000 miles on it. I recently had the little muffler that is right after the muffler,looks like a little round muffler replaced with a straight pipe. i did that because it was a liitle loud. but there is still some noise sounds like puttering noise from under the engine around the exuast manifold?i heard that is where most problems of this kind come from? and would a leaking bad exuast or manifold make like ticking noises and also puttering, puffing noise? i need help!
Sep 13, 2007 at 11:53 AM
BRUCE HUNT
  • 3,754 POSTS
Try placing a large rag on the exhaust pipe with the help of a friend and check for leaks. I suspect the gasket at the manifold and the pipe. But find out where it is leaking. This will also affect the performance of the vehicle as it messes with the readings of the O2 sensor.
Sep 15, 2007 at 11:13 AM
Suggested Repair
With a helper, place a large rag over the tailpipe to pressurize the exhaust and locate the leak. Inspect the gasket between the exhaust manifold and pipe, the suspected source, and repair it because a leak can affect O2 sensor readings and performance.
Conversation Summary
The owner of a 1996 Acura TL 2.5 with 135,000 miles replaced a small muffler with a straight pipe but still hears puttering, puffing, and possible ticking from under the engine near the exhaust manifold. The expert recommends blocking the tailpipe with a rag to find the leak, suspects the manifold-to-pipe gasket, and notes that an exhaust leak can affect O2 sensor readings and performance.
