(15 MPH: RPM:1659, Co2%:14.4, o2%:0.6, HC(PPM):0, co%:0.00, NO(PPM):0, PASS)
(25 MPH: RPM:1650, Co2%:14.4, o2%:0.6, HC(PPM):0, co%:0.01, NO(PPM):16, PASS).
And the only problem is 'Malfunction Indicator Light' showed 'Fail' with a fault code of 'P0420'.
Question: if catalytic converter and oxygen sensor failed then emission should fail, but my test showed 'pass' with excellent numbers.
What should I do? Fight DMV and Acura? :X
SPONSORED LINKS
Saturday, November 3rd, 2007 AT 11:37 AM
