Air Filter Replacement
2007 ACURA TL
26,000 MILES • 6 CYL • FWD • AUTOMATIC
AFMII
How do I replace my engine air filter?
Oct 29, 2010 at 2:11 PM
SERVICE WRITER
  • 9,123 POSTS
Buy the filter. Remove the screw highlighted in the front and find the back ones. Lift off cover and remove the old filter, reverse procedure to install.
https://images.2carpros.com/forum/automotive_pictures/30961_air_3.jpg
Oct 30, 2010 at 1:37 AM
FORTE
How do I access and replace the engine compartment air filter on my 2004 TL?
Jan 27, 2021 at 6:09 AM (Merged)
SATURNTECH9
  • 30,869 POSTS
https://images.2carpros.com/forum/automotive_pictures/416332_2004_acura_TL_air_filter_1.jpg
Air Cleaner Element Replacement NOTE: Do not use compressed air to clean the air cleaner element. 1. Open the air cleaner housing cover (A) and remove the clamps (B). 2. Remove the air cleaner (C) from the air cleaner housing (D). 3. Install the parts in the reverse order of removal. There you go.
BTULSHI
how to replace the engine air filter?
KHLOW2008
  • 41,814 POSTS
Hi btulshi, Here are the procedures. AIR CLEANER REMOVAL/INSTALLATION 1.Remove the bolts (A) and clamps (B).
https://images.2carpros.com/forum/automotive_pictures/192750_AirCleaner04TLFig37_1.jpg
2.Remove the air cleaner (C). 3.Install the parts in the reverse order of removal.
ERIC JUSTIN STEVENSON
Does the type s take the same air filter as the base?
Jan 27, 2021 at 6:10 AM (Merged)
DANNY L
  • 5,648 POSTS
Hello, I'm Danny
No, The TL base model and the Type S air filters are different. I've attached the pictures below with the part numbers from AutoZone parts stores. The Fram CA8475 is for a TL base model and Fram CA9502 is for a Type S. Hope this helps and thanks for using 2CarPros.
DANNY L
  • 5,648 POSTS
Hello again.
Here is a tutorial showing how to replace an air filter.
https://www.2carpros.com/articles/how-to-replace-a-car-air-filter
I've attached a few picture steps below showing how to replace the air filter on your Acura. Hope this helps and thanks again for using 2Carpros.
Danny-
