2006 Acura TL Lower control arm busings
2006 ACURA TL
91,000 MILES • 6 CYL • 2WD • AUTOMATIC
KWDAK
What does it mean when the dealership recommends "lower control arm busings" at next service?
Oct 4, 2009 at 2:01 PM
HONDA TECH 1818
  • 536 POSTS
It means your bushings are cracking and it could get worse over time, So they recommend new bushing next sevice.
Oct 30, 2009 at 5:13 PM
KWDAK
kng1818,
Thanks for your response.
Is this a big job? The bushing only cost about $10-15. I am guessing there will be a lot of labor costs involved. Will they also suggest I replace the lower control arm? Are these bushings on both sides of the car? If so, should they all be replaced at the same time?
I am just preparing myself for my next visit to the dealership.
Thanks.
Karl
Oct 31, 2009 at 9:13 AM
HONDA TECH 1818
  • 536 POSTS
It's not a big job, your front suspension has two front lower control arms that holds the knuckle and shock in place. You don't have to replace the lower control arms, the dealer could replace the compliance bushings only. it's better to replace both compliance bushing, they will need to remove the lower control arms and put it on a press machine to press the compliance bushing out to replace it.
Here a picture of the lower control arm components, #8 is the lower control arm and # 10 is the compliance bushing.
Nov 1, 2009 at 3:19 AM
KWDAK
kng1818,
Again, thank you for your help. The illustration was a big help. I didn't even know what the bushings were until I saw the picture.
Karl
Nov 1, 2009 at 1:40 PM
HONDA TECH 1818
  • 536 POSTS
Car repair can be confusing and difficult at times. I'm glad I was able to help you.
Nov 1, 2009 at 2:35 PM
