2005 Acura TL Power Steering
84,500 MILES • 6 CYL • FWD • AUTOMATIC
BERIDAN
My Acura TL is extremely noisy when cold. It's a loud windy noise that appears to be coming from the power steering pump. I suggest this because the noise gets louder, much louder, when the steering wheel is turned. The noise settles down and frequently goes away completely when the car warms up. I thought it might be a serpentine belt but I don't recall having one increase its noise level when the wheel is turned. There are very small button-sized drops of hydraulic fluid showing up in my garage. Any suggestions for a fix?
Oct 3, 2009 at 9:50 AM
JIRIVERA
I had that same problem with my acura. The problem was faulty power steering pump. The problem occured again, I was hearing knocking sound again. The problem this time was two bad axles on the front and one bearing. Check with the dealer because it is defective. If you have an extended warranty it will help. The job cost a little over 2000 dollars. Hope this helps. Good luck.
Nov 4, 2009 at 10:35 AM
BERIDAN
Took it to the dealership. Turned out to be a faulty O-ring. Replaced at total cost of about $130.00. No problems since.
Nov 4, 2009 at 2:24 PM
