Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Acura
TL
Engine Cooling
Coolant Flush
2005 Acura TL MAINTENANCE
2005 ACURA TL
35,000 MILES • 6 CYL • FWD • AUTOMATIC
JERRYD425
MEMBER
1 POST
WHEN SHOULD YOU REPLACE COOLANT IN THIS CAR?
Mar 21, 2010 at 4:40 AM
LEGITIMATE007
Experienced Mechanic
coolant should kinda be played by eye, if it is anything other than the flourescent green/yellow than it should be changed or the system should be cleaned. but here is some info for you
Mar 21, 2010 at 7:03 AM
LEGITIMATE007
https://www.2carpros.com/maintenance/checking_fluid_levels.htm
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
