2004 Acura TL can valve adj and new catalytic converter sol
78,600 MILES • 6 CYL • FWD • AUTOMATIC
GLOCO
in may 2009 took car to oil express for oil 2 weeks later noticed oil down half way , 2 more week later went to acura after 800-1000 mile. dealer said car was bone dry no oil on stick, started comsumption tests now 8 months later dealer recommends valve adjust and replace catalytic converter to help pass emission test. dealer mention possible deeper internal engine problem may require engine brk down who do u trust?
Mar 11, 2010 at 7:10 AM
2CARPRO JACK
  • 11,533 POSTS
The cat converter should be covered under the federal emissions warranty.Have a leakdown test done on the engine, that will let you know if the oil is getting in past the rings.not sure how necessary a valve adjust would be at that mileage either, but its possible it may need it
Mar 11, 2010 at 8:55 AM
