2004 Acura TL acuator
SEPTWOMAN2001
  • 2004 ACURA TL
Interior problem
2004 Acura TL Automatic
can't unlock passenger front door. Have to manually unlock. I believe the acuator needs repair
Thursday, September 30th, 2010 AT 1:59 PM
KHLOW2008
  • 41,814 POSTS
Hi septwoman2001,
Yes, seems the door lock actuator is bad. It could be due to wiring fault. Remove the door panel and test the actuator by applying battery voltage to it and reversing the polarity to test the locking and unlocking functions.
If actuator does not work, it has to be replaced.
Thursday, September 30th, 2010 AT 2:46 PM
