2003 Acura TL Termperature Control Dial
10,400 MILES • 6 CYL • FWD • AUTOMATIC
HOOVERB
The Temperature Control Dial seems to have stopped working. When the A/C is on, it keeps cooling until it's freezing...then I have to turn off the A/C until it gets warm...then on and back to freezing. I can no longer set a desired temperature even though it shows up in the display. Can this be easily fixed?
Sep 16, 2010 at 1:32 PM
KHLOW2008
  • 41,812 POSTS
Hi hooverb,
It is possible the thermistor at the cooling coil is faulty or improperly installed.
Diagnostics have to be performed to locate the actual cause.
Sep 17, 2010 at 3:27 AM
