2003 Acura TL missfire code
JOSHUA SIMMONS
Computer problem
2003 Acura TL 6 cyl Front Wheel Drive
The engine light is on and so is the traction control light. It is running rough and throwing a misfire code. The spark plugs were changed and it is still having problems. If I could get some advice on what to do next I would appreciate it. Thanks for your time.
Nov 2, 2009 at 2:22 AM
HONDA TECH 1818
  • 536 POSTS
It could be one of the ignition coil are bad.
Nov 2, 2009 at 4:35 AM
