2003 Acura TL low beam headlight
2003 ACURA TL
JRL711
2003 Acura TL 6 cyl 85000 miles
I have ordered a D2R HID headlamp and want to know the steps to replace the bulb. Also if the problem is not the bulb, how do I replace the igniter module and/or the inverter (ballast)?
Thank you,
Jim
Jul 30, 2010 at 2:03 AM
KHLOW2008
  • 41,814 POSTS
Hi Jim,
You should perform test to confirm what is wrong before proceeding with replacement.
I have emailed you the files, hope they are helpful.
Jul 31, 2010 at 3:45 AM
JRL711
Thanks for the information. I will do the tests first, however, if it is the ignitor or ballast, are they located inside the cover that I would remove to replace the bulb?? Is there any similar instruction sheets for the ignitor or ballast replacement??
Thanks again for your help!!
Jim
Aug 1, 2010 at 7:17 AM
KHLOW2008
  • 41,814 POSTS
There are no instructions and information on the inverter and ignitor locations and replacement procedures in our database. I managed to get the diagram from another site but do not know if it is the correct one as it is not labelled. Item # 7.
https://images.2carpros.com/forum/automotive_pictures/192750_HIDComp03TL_2.jpg
Aug 1, 2010 at 4:34 PM
JRC1976
I am having the same problem, any way I can get some info on how to troubleshoot? Thanks!
Feb 5, 2011 at 8:30 PM
KHLOW2008
  • 41,814 POSTS
HID LAMP SYSTEM TROUBLESHOOTING
CAUTION: Never turn on the combination light switch before fitting the HID bulbs to their bulb sockets and completing the reassembly of the
headlight assembly.
1. Check the No. 43 (20 A) and No. 45 (20 A) fuses in the under-hood fuse/relay box.
Are the fuses OK?
YES -Go to step 2.
NO -Replace the fuse (s), and recheck.
2. Substitute a known-good HID bulb and turn the combination light switch ON.
Does the headlight low beam come on?
YES -Replace the original HID bulb.
NO -Go to step 3.
3. Disconnect the 2P connector from the inverter unit.
4. Turn the combination light switch ON.
5. Measure voltage between the No. 2 terminal of the inverter unit 2P connector and body ground.
Fig. 34: Checking Voltage At Inverter Unit 2P Connector
Is there battery voltage?
YES -Go to step 6.
NO -Repair open in the wire between the under-hood fuse/relay box and the inverter unit.
6. Turn the combination light switch OFF.
7. Check for continuity between the No. 1 terminal of the inverter unit 2P connector and body ground.
Fig. 35: Checking Continuity At Inverter Unit 2P Connector
Is there continuity?
YES -Go to step 8.
NO -Repair open in the wire between the inverter unit and body ground. If the wire is OK, check for poor ground at G201 or G301.
8. Measure resistance between the No. 1 and B terminals and the No. 2 and A terminal of the igniter unit.
Fig. 36: Measuring Resistance
Is there about 1-2 ohm ?
YES -Substitute a known-good inverter, and recheck. If the symptom goes away, replace the original inverter unit.
NO -Replace the igniter unit.
© 2008 Mitchell Repair Information Co., LLC.
Feb 6, 2011 at 10:33 AM
