Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Acura
TL
Engine Cooling
Coolant Reservoir
Replace/Remove
2003 Acura TL Engine coolant reservoir removal
2003 ACURA TL
105,350 MILES • 6 CYL • FWD • AUTOMATIC
MIKE94
MEMBER
1 POST
Is there a bolt or screw on the bottom of the reservoir that holds it in. Suggestions to remove reservoir to clean it out.
Jun 15, 2010 at 2:23 PM
JEREMIAH
Experienced Mechanic
no, just that bracket that holds it to the side.
you can pull it straight up to release it.
Jun 20, 2010 at 1:51 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
