2003 Acura TL Brake and Steering system lock up!
82,000 MILES • 6 CYL • 2WD • AUTOMATIC
MORETTICA
I have a 2003 TL Type-S with around 82000 miles on it. The car is in great condition and I rarely have issues. About a week or two ago, my Brake indicator in the dash came on. It came on while I was driving...but the brakes were working fine. Everything was acting normal. I stopped the car and turned it off...and the light reset. Every once in awhile since then, the light will just come on and stay on until I turn the car off. I checked the Brake fluid...and I think it is fine. It isn't max, but it is nowhere near the min line. Well yesterday, I was in a parking spot. I turned the car on...the brake light came on and stayed on. I pressed the brake and it worked fine. I put the car in reverse to back out and then let me foot off the brake. The car rolled back and I went to turn the wheel to back out and it was extremely stiff. Not locked...just ridiculously stiff. I tried to press the brake pedal and the pedal was very stiff. The car continue to roll backwards and the brakes and steering were not functioning at all. I popped the car back into Park and then tried it again. Same thing... So I put it back into park and turned the car off. I turned it back on..and the light went away and all of the functions worked perfectly. No issues whatsoever now... Regardless...that was really scary because I have never seen a problem like that...effecting both brakes and steering...not a good combination.
Also...These are things I was noticing today while driving. These things happen a lot, but I never thought of them as significant...but they could be related. When I press the brakes harder than average, the steering wheel shakes slightly from side to side. If I slam on the brakes, it shakes a lot. I notice that my car will sometimes shift to one side slightly if I hit the brakes too hard. It will pull to one side or another. It is also becoming more difficult to stop. I noticed it today...I was pulling up behind someone at a stop light and I was applying typical pressure to stop and I was getting really close and had to slam on the pedal at the last second to fully stop...
Mar 17, 2010 at 2:15 PM
KHLOW2008
  • 41,812 POSTS
The only explanation I can think of for the above was that the engine cut off and when this occurs, the brakes and steering would be stiff.
The brakes puuliing to onoe side is most likely cause by a bad control arm or its ball joint.
The brakes vibrating should be caused by bad rotors and this would also cause braking efficiency.
Get the brakes checked as this is a safety hazard.
As to the brake indicator lights showing, is it the park brakes only or with other indicator lights such as ABS etc?
Mar 18, 2010 at 8:13 AM
