Heater blower fan does not work
75,000 MILES • 6 CYL • FWD • AUTOMATIC
56FORDMAN
I have a 2003 Acura TL and when I turn the heater on the controls work however no air comes out hot or cold. I have checked the fuses and all the fuses are good. Thanks for any comments.
Dec 30, 2007 at 5:38 AM
TONY01
  • 20 POSTS
My 1999 TL did the same. The Problem was that the connector at the blower housing had overheated and partially melted. There is a TBS for 99 to 03 TL's on the blower harness. Mine had been done but after 10 years and a bad design it still happened. If this is the case a trip to the local junkyard will get you a splice with a good connector & blower. Or take it to the shop with this info.
Apr 26, 2021 at 5:01 AM
SQM
  • 6,383 POSTS
The blower fan can be inoperative due to a bad relay, wiring, or a faulty motor.
First check the relay, it is located in the under-hood fuse box (see diagrams below).
Check for any corrosion or burnt pin(s).
This relay can also be tested.
Here is a helpful guide:
If the relay is good, check to see if there is power to the blower motor harness. If there is power at the harness, then the motor is likely bad. Be sure to check for any melted connectors at the blower motor.
The blower motor is located under the passenger side dash.
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
Oct 28, 2021 at 12:14 PM
