2002 Acura TL turn light not working
14,000 MILES • 6 CYL • 2WD • AUTOMATIC
LIBAN617
Hi
My turn lights is not working all fuses relays is ok and i evan buy a new swiitcher still no working but all hazed lights is ok aswell// can't find the issue please help
Thanks.
May 31, 2009 at 12:20 AM
MMPRINCE4000
  • 8,548 POSTS
If turn signals do not work on either side, then most likely a turn signal switch (assuming bulbs are OK).
May 31, 2009 at 12:24 AM
LIBAN617
I put a new switch still not working either way
May 31, 2009 at 12:54 AM
MMPRINCE4000
  • 8,548 POSTS
Check wiring in trunk, the wiring can sometimes work loose where bulbs plug in.
Check flasher unit under dash.
Jun 1, 2009 at 12:35 AM
