2002 Acura TL Tranny slippng @35mph when @D5 but ok @ D4
2002 ACURA TL
141,000 MILES • 6 CYL • FWD • AUTOMATIC
RICMAC007
3 weeks ago all my tranny fluids burst out while running in the highway @ 90mph. had it towed home, checked out the following day, found 6 or more screw got loose. tightened them and had the tranny flushed ( 2x with reg. dextron III and the 3rd is Z1 from honda). the car runs good @ D4 but @ D5 trans slips @ 30mph. engine vibrates also @55mph whether @ D4 or D5 unless you accelerate at that speed. I noticed that engine oil is also leaking underneath by the bolts, where the seal is, at the bottom of the engine. tightend them , but still leaking. please advised me on how to approach this problem.
Oct 16, 2010 at 4:30 PM
KHLOW2008
  • 41,814 POSTS
Hi ricmac007,
The loose bolts and oil leakage indicates a flaw in the transmission assembling and this has caused internal damages. Pressure is leaking internally and the trans would have to be rebuilt or replaced to rectify.
Oct 22, 2010 at 2:39 AM
