2002 Acura TL spindle nut on rotor
2002 ACURA TL
116,000 MILES • 6 CYL • FWD • AUTOMATIC
DAFAUGHT
replacing my brakes and rotors and I cannot get the spindle nut off of the front of the rotor to slip it off. Any tips to remove the nut?? Also why is the one edge bent down in the groove of the axle
Apr 6, 2009 at 9:55 AM
BLACKOP555
  • 10,386 POSTS
try heating it up with a torch.
you have to have wheel on and vehicle on ground when you attempt to loosen it. edge of what is bent? can you get a picture.
Apr 7, 2009 at 12:11 PM
