rear view mirror
80,000 MILES • 6 CYL • 2WD • AUTOMATIC
RHCOOK
How do you remove the inside rear view mirror?
Feb 16, 2009 at 1:08 AM
DOCFIXIT
  • 18,828 POSTS
Here are the instructions and diagrams to help you remove the rear view mirror. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Feb 17, 2009 at 1:25 AM
MOOREV1
Looking for advice as to how to remove the electronic mirror from its seat on the windshield without breaking the windshield. The clasp is very tight.
Jan 10, 2019 at 10:17 AM (Merged)
TONY01
  • 20 POSTS
I had the same problem in my 99. If you are replacing the mirror with a new. I went to the junkyard and the guy pulling my replacement broke the windshield and the mirror. To no avail I went home and did the job myself. Asuming you are disposing the mirror you are pulling. I used my Dremel Tool. Using the metal cutting disk. First cover your dash with a blanket or equivalent. Very carefully cut the black metal housing where the metal ball resides. All you need is to cut enough right in the middle until you feel the mirror housing gets very loose and it will come right off.
