2001 Acura TL neither heat no air work in my car
REALTOR JAN
Air Conditioning problem
2001 Acura TL Front Wheel Drive Automatic
I was driving the other day and my airconditioner seemed to keep trying to shut off ... it eventually stayed on and worked fine.. yesterday started the car turned on the air worked fine... then went over a small bump in the road and the AC totally shut down.. nothing works there no blower no sound at all from the engine that the AC is coming on... help
Oct 10, 2010 at 6:48 AM
F4I_GUY
  • 3,302 POSTS
Locate the blower motor connector behind the glove box and with the fan speed on, check for power and ground. If you have both, replace the motor, if power or ground are missing, check the circuit (relay, fuse, switch, etc)
Oct 14, 2010 at 11:14 AM
