If these transimissions were anything like the 2001's 02 and 03's then the trans may be getting ready to go. Mine was doing the exact same thing so I check the fluid and found it to be low and a little burnt. I do not think you can just add fluid to these, has to be pumped in at the dealer. I would check with your dealer since these were so bad there was even a recall on them at one point. I know it applied to my 01, im not sure about the 2000's
Jan 21, 2010 at 8:40 AM
