2000 Acura TL Shakesafter turning on.
136,000 MILES • 4 CYL • 2WD • AUTOMATIC
TTHEO
For some reason my car turns on just fine but shortly thereafter it shakes a lot and seems to want to die. Once driven for a while it seems to be fine.
Dec 17, 2008 at 9:39 AM
KHLOW2008
  • 41,812 POSTS
Hi ttheo,
Seems the idling system is not functioning as it should be and I believe a clean up of the throttle body and Idle Air Control valve should help.
Does the Check Engine Lamp shows?
Dec 20, 2008 at 4:03 PM
