2000 Acura TL Power steering pump
99,990 MILES • 6 CYL • FWD • AUTOMATIC
MARIO HERNANDEZ
Had timing belt replaced. During replacement, seems like steering pump had to be disconnected. After re-installed, steering pump started making humming and squeeking noise. I was advise system had air in it and should go away after a few miles. 20 miles later, noise still there. Now being told maybe need to flush system. Will flushing fix the problem or does the pump now have to be replaced?
I have topped it off and that did not work.
Jul 7, 2008 at 12:21 PM
MASTERTECHTIM
  • 4,750 POSTS
topping off the fluid level should take care of it.
Jul 7, 2008 at 12:27 PM
