2000 Acura TL changing a ceased rear caliber
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
EBOT
how to go about changing out a rear caliber and install new rotor and pads
Dec 2, 2008 at 10:26 AM
F4I_GUY
  • 3,302 POSTS
I assume you mean the rear caliper.
First of all, did you try to push it back into the caliper? or did you twist it back in? Because those calipers are not like the front calipers that just push back in. They need to be pushed it.
If it is still seized, then since you already have the caliper off from the anchor all you need to do is unbolt the flex hose from it and possibly the parking brake cable if it does not have parking brake shoes.
But first make sure that it is seized before you replace it. Alot of people think the rear pistons just push back in, when infact they do not.
Apr 14, 2021 at 7:30 AM
