1999 Acura TL Temperature gauge
15,000 MILES • 6 CYL • 2WD • AUTOMATIC
P_SHAPIRO
The temperature gauge does not work. Is the cause most likely the temperature sending unit? If so, where is it located?
Apr 23, 2009 at 12:50 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Suspect faulty ECT sending unit, located at top rear of engine, on water passage.
Thanks for using 2CarPros.com!
Apr 23, 2009 at 1:12 PM
