The temperature gauge does not work. Is the cause most likely the temperature sending unit? If so, where is it located?
Apr 23, 2009 at 7:50 PM
BLUELIGHTNIN6
✓ASE Certified Mechanic
Suspect faulty ECT sending unit, located at top rear of engine, on water passage.
Thanks for using 2CarPros.com!
Apr 23, 2009 at 8:12 PM
