1999 Acura TL Radio, Interior Light, Whiper slow speed NOT
COLOMBIANSNOW527
Electrical problem
1999 Acura TL 6 cyl Two Wheel Drive Automatic 200.00 miles
i changed the battery yesterday and since then my radio doesnt turn on, the interior light doesnt turn on and when i turn the whiper in slow speed doesnt turn on either, i brought it back to autozone and they checked the fuse box and they said theres no fuse for the radio, whipers and interior light.
could you please tell me whats wrong with my car and if its a fuse, which one is it?
thank you
Jun 6, 2010 at 12:44 AM
JIMMYL645I
  • 39 POSTS
Hi friend, did your TL have radio, interior light, and wiper prior to exchanging out your battery?
if the answer is yes, then it should STILL have those 3 functions even if the battery was replaced unless someone accidentally removed all 3 of those fuses. ( unbelieveable )
now if they said that the 3 fuses are 100% missing and they are sure of it, then we can skip all that non sense and get right to getting you some help.
you drive a 1999 TL correct? if this is right please respond back, and i will forward you a diaphram to the fuse(s) location and what amp it takes so you dont fry your wonderful car up =].
look forward to helpin you.
Jun 6, 2010 at 10:47 AM
JEREMIAH
  • 217 POSTS
fuse box is at the edge of the passenger's front dashboard,beside the glove box. the panel is parallel to the passengers door when it is closed.
just pull the bottom of the panel out towards the door and check the top right fuse. should be a 20 amp.
btw there's another fuse box at the opposite end of the dashboard
Jun 12, 2010 at 5:57 PM
