1999 Acura TL power seat back doesnt work
1999 ACURA TL
115,000 MILES • 6 CYL • FWD • AUTOMATIC
VINNYACURA
Power seat back stuck will not recline at all. The power seat base moves back and forth up and down, but the seat back does not move. is this the motor a relay a fuse?
Jul 8, 2008 at 2:55 AM
KHLOW2008
  • 41,814 POSTS
Hi vinnyacura,
Sometimes the motor gets stuck when over run. Give the motor soome knocks while operating and it might work. You might need to give the motor gears a twist to get it going.
Check for broken or disconnected wires under the seat.
Should not be the fuse as the forward/reverse motor is working.
Jul 8, 2008 at 6:08 PM
VINNYACURA
i'll try it .
Thank you
Jul 9, 2008 at 1:44 AM
