1999 Acura TL My car jumps between gears when cold
90,000 MILES • 6 CYL • 2WD • AUTOMATIC
MAFLORES
Hello
My Car is jumping between gears when it is cold. Then when it reaches normal operating temperature it is ok. Is it the transmission?Thank you!
May 25, 2010 at 2:17 AM
F4I_GUY
  • 3,302 POSTS
Yes it is the transmission. Those vehicles are known for failing transmissions. Bring it into a transmission repair shop and have them diagnose it. You will probably need an overhaul.
May 28, 2010 at 9:17 AM
