1999 Acura TL Idling High and Low
1999 ACURA TL
122,000 MILES • 6 CYL • FWD • AUTOMATIC
KELLY327
Acura 3.2 TL is idling high and low while in park and stopped at a traffic light. Runs fine while driving. What could the problem be?
Jan 1, 2008 at 1:38 PM
JEREMIAH
  • 217 POSTS
probably an idle air control valve commonly called IAC valve.its common.no check engine light though?
Jan 5, 2008 at 5:24 PM
KELLY327
The check engine light did not come on. It only idles high and low sometimes because it hasn't done it since I sent the question in to you. Could a clogged fuel filter or trash in the throttle body cause this?
Thanks,
Kelly327
Jan 6, 2008 at 7:36 AM
JEREMIAH
  • 217 POSTS
unlikely to be fuel filter or throttle coz its intermittent. could be a leak somewhere in the intake or throttle body.....but you said it's fine now. good luck
Jan 6, 2008 at 4:38 PM
