1999 Acura TL dash
1999 ACURA TL
157,000 MILES • 6 CYL • FWD • AUTOMATIC
TBRADY3185
when you put the car in tiptronic mode there is a light that is supposed to light up telling me what gear i am in and it doesnt light up. but witht the gear light the main strip with the miles and trip on it also dont light up? but sometimes it will turn on for a little bit and then just shut off after i hit a bump or something so i figured it had to be a loose wire
Jun 28, 2010 at 2:49 AM
KHLOW2008
  • 41,814 POSTS
Hi tbrady3185,
It could be a loose wire, loose bulb connectors or a bad bulb that intermittently works when bumped.
Jun 28, 2010 at 6:40 AM
