is removal of the center boult required to change the rotors on this vehicle and what size nut is it holding the rotors to the axel?
May 21, 2009 at 3:50 AM
MPIRE73
MEMBER
If im not mistaken you have to remove the hub assembly to remove the rotors. Not sure about the size.
Apr 14, 2021 at 7:27 AM
ZYPKODE
MEMBER
1 POST
36mm socket
JEREMIAH
✓Experienced Mechanic
i think its the earlier year model that requires removal of the hub. if im right, you will need a metric sizes 19, 17, 14, a hammer and most important is an impact driver with a #3 phillips end. be careful not to hammer the driver too hard or you might end up having to replace the phillips bit.
