1998 Acura TL rotors
1998 ACURA TL
JAEGETA
is removal of the center boult required to change the rotors on this vehicle and what size nut is it holding the rotors to the axel?
May 21, 2009 at 10:50 AM
MPIRE73
  • 18 POSTS
If im not mistaken you have to remove the hub assembly to remove the rotors. Not sure about the size.
Apr 14, 2021 at 2:27 PM
ZYPKODE
36mm socket
JEREMIAH
  • CAR REPAIR CONTRIBUTOR
  • 217 POSTS
i think its the earlier year model that requires removal of the hub. if im right, you will need a metric sizes 19, 17, 14, a hammer and most important is an impact driver with a #3 phillips end. be careful not to hammer the driver too hard or you might end up having to replace the phillips bit.
