1998 Acura TL Heater blows cold air when car is not moving
178,000 MILES • 6 CYL • FWD • AUTOMATIC
DEREK4911
My 98 Acura blows cold air when the car is in park or I'm stopped at a light. When the car is in motion the heater seems to work fine. The antifreeze levels are good in the radiator and the resevoir. Any ideas on what would cause this?
Nov 17, 2009 at 11:42 AM
RYGALLANT555
  • 5 POSTS
thermostat or begining of head gasket failure....usually due to fan switch or wiring.....they go and you don't usually notice then all of the sudden car has no heat and then revs in park then when gasket goes it will smoke and overheat....then junk
May 9, 2010 at 1:31 AM
