1997 Acura TL transmission sliooing gears
175,000 MILES • 6 CYL • 2WD • AUTOMATIC
SLICKK39
car hesitates before changing gears. after passing second gear, it shifts as normal. while trying to change first or second gear, it "jumps" to change gears. car has transmission oil. what is wrong with the transmission?
Apr 10, 2009 at 9:44 AM
KHLOW2008
  • 41,812 POSTS
Hi slickk39,
If you mean when upshifting from 1st to 2nd gear, trans jerks or judders, the 2nd clutch is failing and a trans rebuilt is the solution.
Apr 11, 2009 at 2:42 AM
