1997 Acura TL Left Headlight daytime and bright light does n
1997 ACURA TL
RUSHDELITE
Electrical problem
1997 Acura TL V6 Front Wheel Drive Automatic 115000 miles
When I start the engine, a high pitched signing noise comes from the area below the glove box. At this point the left side daytime light does not come on. (right side is on) If I turn the lights on, the high pitched noise goes away and both headlights work. If I switch to bright lights the left side bright light does not work.
I changed the light bulb but this did not rectify the problem. I also cleaned the 3 prong plug that plugs into the light bulb but still no luck. Please advise on how I can rectify this problem. Thanks.
Dec 5, 2007 at 10:19 AM
2CARPRO JACK
  • 11,533 POSTS
That is the DRL control module having a problem. If replacing the bulb didnt fix it, the problem could eb the control module itself. Check all connections to be sure they are clean and tight at the controller
Dec 6, 2007 at 2:24 AM
