1997 Acura TL climate control panel
13,000 MILES • 4 CYL • 2WD • AUTOMATIC
JSPIVEY
air conditioner was working fine and than the climate control panel appears to be stuck, every element on the climate control panel is at maximum level but it is hot air and I can not the system off. the fan motor was replaced about 6 months ago.
Jul 10, 2010 at 2:19 PM
KHLOW2008
  • 41,812 POSTS
Hi JSPIVEY,
Thank you for the donation.
Symptoms indicates a possible fault with the control panel. This item is known to give way intermittently and requires replacement to rectify.
Jul 10, 2010 at 6:52 PM
