1996 Acura TL Rear O2 Sensor
MPIRE73
  • 18 POSTS
Electrical problem
1996 Acura TL Front Wheel Drive Automatic 170000 miles
My rear O2 sensor is faulty according to my codes on my OBDII reader. I have located the sensor, but cannot get to the the wire harness clip which is stuffed up into the bottom of the body of the car. I've tried to pull it out so i can actually see the clip and unhook it, but it doesnt seem to have much "play" to do so. Is there a trick like pulling out the back seat or trunk panels to get to the clip?
Feb 27, 2009 at 2:46 AM
MPIRE73
  • 18 POSTS
Just bumping for assistance. Ive tried 3 times already to remove the rear sensor and i can get to the sensor portion, but the clip i cannot reach as to the reason stated above. I dont want to have to splice since i have a replacement sensor with the clip already. I know its the rear and not "as" important, but i like to keep the check engine light off y'know. :)
Mar 19, 2009 at 12:49 AM
