1996 Acura TL egr vavle
1996 ACURA TL
175,000 MILES • 6 CYL • FWD • AUTOMATIC
ENEGUE
how to clean
Feb 9, 2009 at 10:11 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Better off replacing it...cleaning it is only a temporary fix which usually only lasts for a few miles. Below are the cleaning techniques for you to try if you decide not to replace it ..
To clean the valve, simply spray carborator cleaner on and in the valve and wipe the dirt off with a cloth. Be very careful not to get it into
the canister, as the carb cleaner is a very powerful detergent that will eat away the insulation on the windings in the sensor.
Thanks for using 2CarPros.com!
Feb 9, 2009 at 6:33 PM
