1996 Acura TL Cruise Control
ACURA1996
1996 Acura TL Front Wheel Drive Automatic 86000 miles
My cruise control has stopped working, the light on the dash goes on and off when I push the set and resume buttons, do you have any suggestions?
Thank you for your service,
AC
Oct 25, 2010 at 11:21 PM
KHLOW2008
  • 41,812 POSTS
Hi acura1996,
One of the most common cause of the cruise control malfunctioning is the brake switch. Check the brake switch to pedal clearance.
If clearance is excessive, the cruise control would be prevented from operating. Place a piece of cardboard between the switch and pedal and test if the cruise works.
Oct 26, 2010 at 2:38 AM
